never thought of it like this but
The locking hub acts as a sort of a fuse
It fails instead of much more expensive and complicated to repair parts inside the axle etc.
Is that true?
Locking hubs
Re: Locking hubs
To an extent: free-wheeling hubs usually are permanently lubed and should not fail under normal use. They prevent the front drivetrain from rotating when the truck is in motion and save a bit of gas mileage. The truck steers a bit easier as well.
As long as you check them to ensure they are in "free" mode, nothing should fail under normal use. I mention this because some kids like switching one to "lock" as a prank, so I usually do a walk around before moving out, or when returning to the truck when it's in parking lots, etc.
Re: Locking hubs
usually the freewheel hubs won't break unless they hit something like a rock or stump, i wouldn't count on them giving out before twisting off an axle.
I had one hub freeze up in the "free" position, making it so i couldn't climb out of the icy ditch across the road...lucky the winch was still working.
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Fairbanks, AK
Photo Gallery
Re: Locking hubs
When I first got the ambulance.
One hub was super easy to turn and the other had normal resistance.
The sloppy one is the one that died
