Hello all,
Im new here and i tried a search and did not come up with anything. Im build a 1963 m37. I replaced the locked up 230 with a 361 chevy/700r4 combo. Im now needing a radiator. What would be a good replacement that does not require much modification?
New build radiator question
Reason: Moved to Technical Section for Upgrades and modifications.
Re: New build radiator question
there was talk about an aluminum rad out of a sprint car that was cheep and easy ?
I havent found it yet.
Here you go.
I typed "Aluminum Radiator" into the Search box in the upper right hand corner and this was the second topic down on the list. http://www.g741.org/PHPBB/viewtopic.php ... tor#p56420
