Need the size of...
Need the size of...
...the crankshaft nut on the front (that the crank handle fits into).
Re: Need the size of...
By "size" do you mean the thread diameter and pitch of the threaded end of the cranking jaw, p/n 7702761? I don't have the numbers here at the moment (and the parts catalog doesn't spec them), but I can measure the part when I'm back at my shop tomorrow.
Sorry Elwood, I was not specific enough. I need to know the size of the socket that removes the nut.
Ah. If no one else posts before then, I can measure and post the size tomorrow evening.
Gary,
Mine is 1 11/16". If you don't have a winch a nice long extension works great for turning the motor over. If you have a winch it's less fun.
isaac_alaska
Post by isaac_alaska »
if i remember right a 42mm socket will also do it
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Thanks guys,
Now I need to see if I have the socket in that size....
isaac_alaska
And set the parking brake with the truck in high range, 4th gear, if you're trying to remove the nut
Isaac
Fairbanks, AK
Photo Gallery
ashyers wrote:Gary,
Measured the hex on two different cranking jaws, and came up with the same thing: 1-11/16".
Thanks guys-good advice, too, Isaac!
