Power steering pump choices?
I am using a '76 Dodge (saginaw) power steering box, and was wondering if a late model Dodge power steering pump ('09) can be used? I'm putting in a 5.7 hemi that has the pump with it.
Anyone know?
isaac_alaska
Re: Power steering pump choices?
Post by isaac_alaska »
Should be no problem. As far as I know the flow rates and pressures are fairly similar between pretty much every power steering pump. Being both dodge, the fittings may even match up, if not you may need a couple of adapters at one end
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
