Brake shoe
richard 775472
Brake shoe
Hi All, yesterday I toke the rear weels and drum off, I've notice that the right brake shoe(2) were smaler than the left one. Is this normal , are the front one the same lenght.
Re: Brake shoe
Should have a "primary and secondary" shoe on each wheel.
One is longer(secondary) than the other.
The short shoe goes toward the front longer to the rear,
TGP
TGP
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
Re: Brake shoe
on M37s all 4 shoes should have the same length material. if someone relined them at some point they may have done a primary and secondary by mistake. that is pointless with fixed anchor brakes. cant hurt anything but stock should all be same length.
Re: Brake shoe
We have new shoes for M37 in stock, or we can reline your core shoes. Buying new is the better deal unless you need a special lining thickness due to worn or turned drums. We can rivet on whatever you need.
