brake fluid
junkyardog
brake fluid
Post by junkyardog »
how do i know if a truck i just purchased has dot 3 or silicone fluid
RMS
Re: brake fluid
Post by RMS »
dot 5 is purple
vargaspj
Re: brake fluid
Post by vargaspj »
Sometimes the color is hard to see.
Put some water in a small glass container.
Add a little of the brake fluid.
Swish/stir/shake it around, in other words mix it up.
If it blends with the water, it's DOT 3/4.
If it forms little beads at the bottom of the glass and won't mix with the water, it's silicone based.
junkyardog
Re: brake fluid
thank u
