Air Horns On A M-37?
Tim Powell
Post by Tim Powell »
Hello Crew.
A great Friend of the Family found and donated a set of air-horns to the Powell Family.
I'd like to install then on Lori's M37 but need to ask a few questions.
Anybody able to recommend an electric 24 volt mini air compressor??
Also, any idea of the max air pressure I should run to these horns??
They look to be off a Military vehicle but I ain't got a clue from where.
Twin Trumpet Air Horn
IMGA1208 (300 x 400).jpg (36.75 KiB) Viewed 1034 times
Re: Air Horns On A M-37?
Hi Tim,
Those appear to be off a Deuce and 1/2. I can't recommend a compressor or the recommended PSI but plan to install a civvy set of air horns on mine-so tired of idiots slashing in front of me when they're making turns, etc.
Just my 2 cents,
Tim Powell
Hey Buddy.
I guess we're in this project together. Loud horns save lives!
Tim you are going to need one or two reserve air tanks otherwise a small compressor will not have enough flow volume to make the horns work properly.
Monkey Man
Site Admin
Site Admin
Post by Monkey Man »
You can get 12 and 24V steel fluted air horns for a reasonable price, easier to install and still more than loud enough to destroy the underpants cleanliness of most bad drivers...
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
Tim Powell
Hey Guys.
As far as the reserve air tanks I figured a set off an old rig. Plenty of those sitting around.
Guess I never thought about 24 volt electric, I knew they made 12 volt trumpets.
I'm sorta' falling behind on my production again. Anybody ever had a "bad day" in the shop?
That said, a bad day in the shop is still better than a good day at work! :D
Freightliner broke down last week on the road. :?
