Heater hose diameter?
isaac_alaska
Post by isaac_alaska »
Finishing my manifold, and I need to add a couple of hose barbs to the coolant passage to keep it from icing. What's the stock heater hose size? I'm planning to run the coolant through the manifold by splicing into the hose before it hits the heater, but I don't rememeber what size the hose is and I don't want to drive across town to measure it...
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
52PLOWERWAGON
Re: Heater hose diameter?
Post by 52PLOWERWAGON »
I don't know right now either
but I would like pictures of your manifold
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
isaac_alaska
pics will be posted when it's done! which...should be very soon. just need the hose diameter. maybe it's in the book somewhere, i'll have a look. i wanna say it's between 3/4 and 1"
Isaac
Fairbanks, AK
Photo Gallery
isaac_alaska
dodge m37 headers.JPG (46.62 KiB) Viewed 1202 times
testing to see if the "attachment" tab works for me...if it does, here's the CAD model i built
Isaac
Fairbanks, AK
Photo Gallery
RMS
Post by RMS »
that is beautiful Isaac !
I wonder if the tight transition from the 2 bolt flange to the intake runners will hurt flow? would a larger diameter collector(?) ease the transition. hmm what about a 4 bolt weber flange and a boxy collector?
isaac_alaska
you're right, probably some analysis in this area would not be a bad idea. i kept it this way so i could maintain stock dimensions, although my truck does have a 3" body lift so i could have lifted the carb 3" at least, and probably helped the flow at the transition area. I "should" be able to do some flow analysis in solidworks and try to come up with a better design. This one is very close to stock dimensions in that area though, so at worst it should still be about as good as stock.
Isaac
Fairbanks, AK
Photo Gallery
52PLOWERWAGON
:shock: no turbo :(
but still very nice :mrgreen:
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
isaac_alaska
After a little reading of other guys installing heaters, it looks like 5/8" is the standard heater hose ID on these
No turbo, will strongly consider making a place for one if I build another
Isaac
Fairbanks, AK
Photo Gallery
52PLOWERWAGON
isaac_alaska wrote:After a little reading of other guys installing heaters, it looks like 5/8" is the standard heater hose ID on these
DO IT ! :twisted:
if you do and you are satisfied with the results I would be interested in one for my 230 8)
Its Flathead Turbo Power time :mrgreen: 8)
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
