Rotella is a Diesel engine oil......
Guys ;
I thought you'd like to read this one. I was over on the G503 site on the Powerwagon forum, someone asked about what oil type people use in an M37. A few people responded with their brands and so I then responded and told them that after hearing alot of advice toward the use of Rotella, thats what I started using. Well some guy replies back simply with "Rotella is a diesel engine oil"! Well, maybe so, but its obviously not JUST for diesel engines as is evidenced by its use in 230 gas engines. I just thought it was kinda funny how this guy had to throw that out there.
Rotella....
Yeah I at first thought, "well maybe this guy knows something I don't" so I went out to the garage and checked the label on the jug just to see if what he said had some merit. Yes it does mention use in diesel engines but it says nothing about it NOT being able to be used for other applications. I'm sure had this man been onto something I would have read something like, "not intended for gasoline engines", etc but I didn't.
All I know is my engine showed an improvement in oil pressure and runs quieter now that I have the Rotella in it and that is what I am concerned with. I will continue to use it. I just wanted to share what I had read....
Rotella
I've only seen it in 15W-40, then again thats all I ever looked for so I am sure you could get it in other weights/viscosities.
Yes Rotella T, & Chevron DELO 400 is available in single grades as well as 15-40. You will likely have to go to a distributor to find the single grade products however.
Re: Rotella
The Rotella T 5W40 is their synthetic. I run it in my VW TDI (Turbocharged, Direct, Injection)Nickathome wrote:I've only seen it in 15W-40, then again thats all I ever looked for so I am sure you could get it in other weights/viscosities.
Yes it's a diesel
WalMart stocks it
John
NRA LIFE MEMBER
1954 M37 w/w
NRA LIFE MEMBER
1954 M37 w/w
If you are in or near farm country, might try the ag supply type stores for the 30w Rotella - our local Napa carries it and I run it in the '49 Farmall Cub as well as the garden tractors.
10-4 on the Rotella synthetic - my wife's TDI has been running on it for 7 yrs and the oil analysis always looks good.
FWIW, Chad
FWIW, Chad
Re: Rotella
I believe there is a mix up here, Rotella T is available in a synthetic product. It's also available in the older petroleum oil based product that has been around for years. 2 TOTALLY different products.HOLZINGER wrote:The Rotella T 5W40 is their synthetic. I run it in my VW TDI (Turbocharged, Direct, Injection)Nickathome wrote:I've only seen it in 15W-40, then again thats all I ever looked for so I am sure you could get it in other weights/viscosities.
Yes it's a diesel
WalMart stocks it
Rotella T 15W-40 is API CH/SJ rated wich means is as good as any engine oil rated as SJ. CH is the Compression ignition engine oil rating and SJ is the Spark Ignition engine oil rating. If you do a little research you will find at least 80% of the engine oils intended for gasoline engines are rated SJ.
Rotella T 5w-40 is the synthetic based oil down here in my country
For the record, IMHO, Chevron Delo 400 is the best oil for a diesel engine, another option would be Mobil 1.
I've used Rotella for a while in my 6.2 powered trucks, when Chevron didn't imported Delo 400 for cost reasons, and I can see a 10lbs difference in oil pressure after a long high speed run in the highway.
That's enough for me to turn back to Delo400 as soon as Chevron imported it again. Besides the longer interval between oil changes.
Juan Castro
Buenos Aires
Argentina
Buenos Aires
Argentina
Chevron DELO 400 is my favorite locally available oil also. We used it for years in our heavy equipment with outstanding results. DELO 400 & Rotella T at one time used the same additive package to blend with their products. Not sure if that is still true today.
As far as an over the counter product, I'd recommend Chevron DELO 400 in the 15-40 grade. This is likely the best oil that is available at Wal-Mart.Gerry wrote:Charles,
What do you recommened for use in a stock M37? And should I use it in my M38 as well? She could use a little boost in oil pressure while she waits for her rebuild.
