pioneer rack bolts
Gerry
pioneer rack bolts
Post by Gerry »
Do the bolts start on tailgate side so just bolt head sticks up on tailgate or rack side so nuts on tailgate?
Gerry
53 M37
Re: pioneer rack bolts
I installed mine with the bolt heads on the inside so when sliding things in and out of the bed nothing catches on the threaded bolt shank. If it were installed the other way with threads up when the gate is lowered to the horizontal position the shank would catch if it extended beyond the nut. A nut with a washer protrudes further than just the head of the bolt.
A fastener known as as 'elevator bolt' is ideal, it has a very flat head and won't catch on anything.
https://www.boltdepot.com/Product-Detai ... duct=14880
Dennis
Gerry
Post by Gerry »
Thanks for the imput. I'm trying to keep truck original so want to match that
Gerry
53 M37
mike_l
Post by mike_l »
I couldn't find a picture but I would think the bolt heads would be on the inside. The reflector screw heads are on the inside which I presumed were to minimize snagging equipment or troops. I expect the same thought would be with the pioneer rack.
Mike
Marion, IN
1954 M37 W/OW
1953 M101
Indiana MVPA
Gerry
Post by Gerry »
Gerry
53 M37
m37jarhead
Post by m37jarhead »
PoW wrote:A fastener known as as 'elevator bolt' is ideal, it has a very flat head and won't catch on anything.
Dennis
I found a raft of elevator bolts at my local Ace Hardware store. Many sizes and lengths.
JB
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
