383 Mopar powered M37
57hemicuda
Post by 57hemicuda »
Bought a 54 a couple months ago with the intentions of installing a V8. Drove the truck for a while with the flat head and now the conversion begins. Sold the engine to someone on the board here. Conversion will consist of 383 Roadrunner engine, 727 transmission, with attached 205 transfer case, narrowed Dana 60 dually front with 4:56 gears. 60 in the rear also. Running HumVee wheels with beadlocks. Have a lot of the assemblies built so the conversion should go fairly quick.
57hemicuda
Re: 383 Mopar powered M37
Starting with the engine, used a factory Chrysler truck oil pan which I really didn't care for, pan had no baffling at all. As a hobby I do some roadracing, the one thing that has taught me is that oil pan baffling is very important. I desided to fabricate some baffles and welded them into the pan to keep the oil in the pan near the pickup while climbing and descending hills.
57hemicuda
Engine ready to install
57hemicuda
In the transmission I found a little more carnage then I was expecting. I scrounged some parts and got it together with Redline clutches and bands.
57hemicuda
The front differential I narrowed to get the spring perches to line up. Used a dually front to allow me to run HumVee beadlock wheels. Needed to cut 3.5 inches off of the long tube to achieve the proper alignment.
Tuko
Post by Tuko »
Holy smokes! :shock: nice going so far, keep the pics coming!
51 Dodge M37 W/W 4BT/NV4500
My G741 Registry Entry
57hemicuda
The frame needed to be notched for the oil filter to clear. The mounts had to be fabricated the motor and transmission.
W_A_Watson_II
Post by W_A_Watson_II »
WOW, Great work and a very cool build and pictures!
Will
1946 Dodge Power Wagon
My 1953 Dodge M37 WEB Site
That is daggone impressive! Thanks for the photos, too!
CSCameron
Post by CSCameron »
Fun to watch someone with "skilz", lol. Great job. Keep the pics coming. :mrgreen:
CREEPING DEATH
Post by CREEPING DEATH »
57hemicuda wrote:Engine ready to install
What air filter housing is that? I remember seeing them commonly listed here and there years ago, but haven't been able to find htem lately - but, I'm looking to use one on a Ford ;)
CD
57hemicuda
The air cleaner is from Mopar performance. Got the engine pulled back out the firewall painted, motor mounts, and backer plates sandblasted and powder coated, and then reassemble this weekend.
57hemicuda
The transmission crossmember turned out pretty good, looks pretty OEM
choppa
Post by choppa »
EN-VI-OUS!!!
Man.. you do sweet custom work for sure!
where are you located?
jim lee
Post by jim lee »
I'd guess Parkville MD. Or close by.
-jim lee
