trans np420 syncros
Cav Trooper
trans np420 syncros
Post by Cav Trooper »
Is there a difference in the syncros for the early and late model np420 trans?
CT
HHT 2nd ACR
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
Sal
Re: trans np420 syncros
Post by Sal »
Yes Ct there is . From what I was told the early model (88950) and later model (NP420) as a unit are interchangeable. But the insides are not, they are totally Different and are not interchangeable...You can double check with the site below. Also from what I understand a NP420 transmission out of a Civi Power Wagon will not fit in our trucks.
http://www.jobrated.com/index.html
Sal
:mrgreen:
1954 M37 WO/W
1969 M101A1
Cav Trooper
Sal,
Thanks, I saw a set on ebay and was trying to find out if they would fit my old trans. Just looking at future replacement parts. The ebay ones are for the late model.
CT
HHT 2nd ACR
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
Sal
Post by Sal »
I Know I seen them also. If your interested AB Linn has a set of gears for the early transmission. But No syncros.
Sal
:mrgreen:
1954 M37 WO/W
1969 M101A1
For a couple of years, I was collecting early transmission (88950) parts, but I never did find any synchros. Unless you're doing a restoration for as-built accuracy, the later NP420 is a better transmission, and parts are more readily available. A lot of the first generation M37s apparently received NP420s when their 88950s failed, so an NP420 in a 1954 or earlier M37 would not have been unusual while still in service.
