she RUNS AGAIN!!!
she RUNS AGAIN!!!
My M was running great after all new wires points 12 volt 1 wire system,after taking out the 6 volt one.well she started getting hard to start after about a month of running,she tried but failed to start ,sounded like fuel so I rebuilt the carb ,which was very clean and looked to have been rebuilt before I got it, so I changed plugs, filter ,fuel lines ,frfesh fuel coil wires points condensor,cleaned tank,still no start ,went to electrical ,had spark but not all the time,thought I would change the easy stuff last ,(should have done that first) took the coil wire off again and checked for resistance and nothing ,changed the coil wire and fired right up and purrs like a kitten ,problem solved.sometimes we over think things......thanks for listening ,on to the next project,,,jack
Re: she RUNS AGAIN!!!
Nice job! Let 'er roar!
