Top question
Murf
Top question
Post by Murf »
After looking through some of my acquired "M37 stuff" I found a canvas cab top but I really think it might be for a deuce 1/2 or the like. It has the metal twist fasteners along the exterior of the upper sides (above the driver's and passenger's heads). Rectangular plastic rear window. Also along the bottom (exterior) rear it has straps with metal buckles to cinch it down. Can anyone here give me some confirmation on what I have?
Re: Top question
Sounds like a deuce top to me. Does the inside back edge at the top have two reinforced sections? I ask because the deuce cage has two metal bars running across as opposed to the M37's single bar.
vtdeucedriver
Re: Top question
Post by vtdeucedriver »
Murf wrote:After looking through some of my acquired "M37 stuff" I found a canvas cab top but I really think it might be for a deuce 1/2 or the like. It has the metal twist fasteners along the exterior of the upper sides (above the driver's and passenger's heads). Rectangular plastic rear window. Also along the bottom (exterior) rear it has straps with metal buckles to cinch it down. Can anyone here give me some confirmation on what I have?
A deuce top will have the grommet holes for the ropes like a M-37. No buckles used.
http://linehaulrvn.tripod.com
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
Murf
Re: Top question
Post by Murf »
Pics:
Hopefully these will clear up questions...
Murf
Re: Top question
Post by Murf »
Cal_Gary wrote:Sounds like a deuce top to me. Does the inside back edge at the top have two reinforced sections? I ask because the deuce cage has two metal bars running across as opposed to the M37's single bar.
Only one reinforced strip in that area (pic 4 shows the upper back edge somewhat turned inside out). However it has the snap loops further up that would obviously go around a second bar.
Murf
Re: Top question
Post by Murf »
After more searching, It looks to be a M38A1 winter top. Separate curtains attach at the rear sides. Rear straps go to the tailgate.
Re: Top question
I think you are correct M38 or M38A1 top. If it is a jeep top it will be to long to fit the M37 properly.
sturmtyger380
Re: Top question
Post by sturmtyger380 »
Hi Murf, Sent you a PM. Alan
