I was able to acquire a Braden MU-2 from a WM300, which I plan on installing on my M-37. I have an LU-4 which needs bearings, however I prefer the MU-2.
I know I have seen some pictures before, but does anyone on here have pictures of an MU-2 winch mounted on an M-37??
-T
Braden MU-2
- pwrwagonfire
- SSGT
Re: Braden MU-2
I just added a photo to my (ed Anderson) album of an aftermarket mu2 look alike mounted on an m37 I sold. factory lu4 extensions homemade bumper...
http://g741.org/photogallery/main.php?g ... ewsIndex=1
- pwrwagonfire
- SSGT
Re: Braden MU-2
I have no pics but I woul take the Power WAgon front and rear mounting pieces and utilize them. they are incredibly strong steel. I coul NOT straighten the front angle steel piece the winch bolts to so I took it in to the the metal man fab shop and he said it took a 50 ton press and heat to straighen it out. was barely bent at all. also using the PW parts you incorporate the lower fairlead set up for pulling things from behind the truck. that has been very handy on tight trails when I have had to drag all the chevys and toyotas up behind me on the Nachese Pass.
- pwrwagonfire
- SSGT
Re: Braden MU-2
I'm definitely on board with that idea! I was hoping to use the front mounting piece flat against the front bumper, attaching a fair lead on top. The rear I was going to cut down the PW mounts. I think it's very do-able.Kaegi wrote:I have no pics but I woul take the Power WAgon front and rear mounting pieces and utilize them. they are incredibly strong steel. I coul NOT straighten the front angle steel piece the winch bolts to so I took it in to the the metal man fab shop and he said it took a 50 ton press and heat to straighen it out. was barely bent at all. also using the PW parts you incorporate the lower fairlead set up for pulling things from behind the truck. that has been very handy on tight trails when I have had to drag all the chevys and toyotas up behind me on the Nachese Pass.
Will be sure to post pictures when it comes to fruition, whenever that may be!
-T
- pwrwagonfire
- SSGT
Re: Braden MU-2
xm708 wrote:I just added a photo to my (ed Anderson) album of an aftermarket mu2 look alike mounted on an m37 I sold. factory lu4 extensions homemade bumper...
Sir,
I was wondering, did the winch on this truck fit easily with the PTO drive shaft? If I use the regular M-37 PTO and shaft, will I need to cut and fab to make it fit, or...
I know you said you removed it, so you'd be familiar!
Thanks in advance@
- pwrwagonfire
- SSGT
Re: Braden MU-2
BUMP?
Re: Braden MU-2
Not sure if same length never got the shaft and pto on truck before I sold it.. It look like the winch was in the same position the only strange thing is the shaft that came with the setup is it has a slip joint shaft on it and is not the original shaft. I don't have a shaft to compare it with currently...
ed
ed
