Turn signal help
SydneyM37
Turn signal help
Post by SydneyM37 »
I am putting in new turn signals on my truck using a signal stat turn signal wand, Truck is still 24v.
I am using for indicators LED style, my question is this, does a normal 3 pin Flasher relay work or does LED require something else.
Bruce McCann
Keep em green to keep ya keen
tmbrwolf
Post by tmbrwolf »
If its an elecronic flasher it should work fine, I know the military ones do. A thermal flasher will work but you may have to add a resister to the front lamps to create enough load to the system for it to work correctly.
Ken
SFC USA (ret)
51 M37
52 M38
