brake line vent hose
macibell111
- CPL
I just finished putting in new brake lines from vpw and I noticed there is no vent hose connected to my master cylinder,it has broken off , I will not be fording at all, the petcock is still there ,My question is, do I need to put a vent line in and route it up inside the engine compartment to keep the MC free from dirt or can I just keep the petcock closed or cap it off???
Re: brake line vent hose
You have to have a vent for the MC to work properly. I had the same problem, and solved it by running my vent up the left frame rail, as stock, then making a 90º bend, and going straight up towards the genny, to almost the top of the fender, where I made another 90º, and pointed the end of the tubing straight at the firewall. If that gets wet, then I have bigger problems then water in my brake system. I plan to wrap the loose end with metal screening to keep the mud daubers out, and zip tie it off so it doesn't rattle.
John, in Aiken SC, Where trains run down the center of the parkway
