Oil Bypass
jimmy_stikx
Oil Bypass
Post by jimmy_stikx »
What's the size and pitch of the holes in the block for the oil bypass lines? It's looking like whom ever owned my M ahead of me installed an aftermarket remote filter. One that doesn't look like a spinoff, well any I've seen anyways.
Any info would be appreciated
Re: Oil Bypass
jimmy_stikx wrote:What's the size and pitch of the holes in the block for the oil bypass lines? It's looking like whom ever owned my M ahead of me installed an aftermarket remote filter. One that doesn't look like a spinoff, well any I've seen anyways.
The threaded ports in the engine block oil galley are 1/8" NPT threads
jimmy_stikx
Re: Oil Bypass
Thank you, time to start getting parts to redo the lines to the filter adapter. It's running a PH8A right now, I think I'll stick to it.
Re: Oil Bypass
jimmy_stikx wrote:Thank you, time to start getting parts to redo the lines to the filter adapter. It's running a PH8A right now, I think I'll stick to it.
PH8A is a Fram filter #. That is the biggest junk in filters that exist. I would certainly source a different filter brand such as WIX or BALDWIN.
jimmy_stikx
Re: Oil Bypass
I'll look into those. Would I need to convert back to the stock type filter arrangement?
EDIT:
A quick look on Summit Racing I found a Wix filter with the same threads as the PH8A for the same applications (Ford V8 pushrods)
j mccormick
Re: Oil Bypass
Post by j mccormick »
PH8A is the Fram number but you can get a cross reference at any parts store. That is a very popular and available filter almost anywhere, even at Wally World.
Joe
Re: Oil Bypass
It will be an easy cross reference. Keep in mind most retailers now offer 2 or more lines of differing quality filters. Example, NAPA offers a NAPA Gold line which are the better filters. They also offer a SILVER line which is the cheap stuff. I'd stay with the Gold line.
jimmy_stikx
Re: Oil Bypass
Oreily's carries the Wix 51515 which is cheaper than the race one listed on Summit Racing. When I got it, it had a Mobil One equivalent of unknown age.
I just need to get the drain plugs in so I can drill out the odd ball pan plug (star pattern) and replace it.
Re: Oil Bypass
jimmy_stikx wrote:Oreily's carries the Wix 51515 which is cheaper than the race one listed on Summit Racing. When I got it, it had a Mobil One equivalent of unknown age.
Drain plug sounds like an original, a 1/2" drive ratchet fits the star pattern. That is unless you really have something weird.
jimmy_stikx
Re: Oil Bypass
I'll double check that with my breaker bar. My largest star wont hit it though, I need to see what size that was.
Re: Oil Bypass
You just put the 1/2" drive portion of the ratchet into the star shape of the drain plug, no bit or adaptor involved.
jimmy_stikx
Re: Oil Bypass
Yep,that worked. I still needed a drain plug though, because the one for the bellhousing is missing.
Re: Oil Bypass
The drain plug in the bell housing is standard NPT for thread pitch. You could pick up one with your choice of head style from the local hardware store.
jimmy_stikx
Re: Oil Bypass
I think the ones I have coming with the water pump are 7/8 head's. I just glad to have new oil in it, helped with overheating a tad. A new water pump and thermostat should round out the deal.
Re: Oil Bypass
jimmy_stikx wrote:Yep,that worked. I still needed a drain plug though, because the one for the bellhousing is missing.
There is no plug used in the flywheel housing; except during fording, that hole should be wide open.
