FINELY AFTER MOST OF MY SUNDAY AFTER NOON THE WIPPER MOTOR'S AND ALL WIREING ARE IN AND WORKING BOTH WIPPER ARM'S ON ONLY PROBLEM NOT ENOUGH SWIPPING MOTION, Heater in monted under glove box wireing done ,fan works on all [3] speed's problem #2 pipe plug's one mammy to get them broken loose oop's spoke to soon broke the top one on the water pump what are the plug's made of look's like aluminum, oh well look's like I'LL be sending both the water pump top and the elbo out to the local shop to get them broken then get the radiator fixed put all new hose,s on and it will be done for next winter I hope! all my part,s where pick out of [ J.C WHITNEY] some good some will do for now
will try to post some pics for both as soon as possilable when daughter gets camera back this week end not to good at pictures or getting them on this site always need some help for that !
wippers are only singel speed , and were very eazy to install just take out old vacs and install new the new ones have a threded shaft with two rubber seals one for inside and one for outside just bolt to window and run your wires passenger side to driver side an down to door frame by way of the vac route I came out at bottom of door frame about same hight as dash and came over a bit on bottom of front window and down into a small hole that was all ready there and wired in at back of dash if you go this route I will be more then HAPPY TO HELP if you have any questions . AS I SAID IN FIRST POST EVERY THING WAS PICK UP FROM J.C WHITNEY . WIPPERS & heater , HEATER WAS VERY EAZY HOOK UP . MOUNTED UNDER GLOVE BOX with just six bolts and two breakets all suplied with with wire harness and switch , all total price was about 350.00$ FOR BOTH . I DID HAVE ONE PROBLEM THAT WAS getting the pipe plugs out from water pump as they more than likely been there from day one . best of luck with yours if you do deside to go that way . CANOT FIGURE OUT HOW TO POST PICS BUT WILL BE HAPPY TO EMAIL ALL PICS TO YOU ! [ NICKATHOME ]
CA'NT SEAM TO GET PICS OF BOTH IF YOU WOULD LIKE PLEASE E-MAIL ME I WILL BE HAPPY TO E-MAIL PICS TO YOU , HAVE TRIED FOR TWO DAYS TO GET PICS ON THIS SITE BUT ONLY MAKES ME & my kids GET LESS THEN HAPPY . [fa-get-a-bout-it@hotmail.com] thank you !
THE ONLY WAY I CAN THINK TO POST PICS IS TO TELL EVERYBODY TO GO TO ARE PHOTO ALUBM AND THEN CHECK THEM OUT IT WILL COME OUT LIKE A BROKEN PICTURE BUT IF YOU CLICK ON WHERE IT WILL SAY FULL SIZE YOU CAN SEE ALL PICS INCLUDING THE NEW ALARM SYSTEM I HAVE PUT IN, L.O.L
