This one may seem novice or silly, so bear with me please.
Is there a maximum height that you can raise a wheel(such as when rolling over something or when jacking) before something bad happens? Can the frame be subject to twisting under such a maneuver? Reason I ask is, I did a dumb thing today and backed over my wooden wheel block(Its a piece of one of those wooden landscape timbers) when backing out of the garage. The rear of the truck on the left side went up about 3/12 inches, then down before I realized what had happened. Fortunately I had plenty of interior height and did not hit the top bow against the garage door.
Another question....
Your frame is designed to flex (i.e. twist) under the conditions you describe. Running over your stop block did no damage whatsoever. Rock-crawlers abuse their trucks MUCH more severely than that with no problems.
If you get both wheels on the same side high enough that your center of gravity shifts to the outside of the tires on the ground, your truck will tip over...guaranteed! However, you won't be able to do that with a jack.
That said, I don't think you have a problem. Enjoy your truck!
- SSGT
Go buy an M-715
I actually got stuck by backing one wheel over the borrow pit and suspending a tire in the air. The frame and suspensions do not flex. Tom
www.snakeriver4x4.com
G-7117 Chevy
G-7117 Chevy
Frame
Yeah I didn't really think it would be a problem, but just felt better to ask....I was actually more concerned wit hthe fact that I could have hit the top bow against the open garage door, but from measuring found that I still had plenty of room.
- SSGT
