GOOD MORNING,
My M has not been running well since Sandy. I pulled the plugs, carbon fouled, I pulled the dist, fly weights frozen. I freeded everything up, ordered and received new plugs, points, condensor, rotor, cap. All my TM's got destroyed in the flood. WHATS THE POINT GAP AND PLUG GAP??
THANKS
BOB
TUNE UP S[ECS
Re: TUNE UP S[ECS
.028" to .033" for the plug gap.
points gap is .018" to .022"
Re: TUNE UP S[ECS
TM-9-8030.. July 1953, lists 0.028" to 0.033" for the plug gap ( I gap at .035) , points gap is 0.020" I time mine at 3 degrees before TDC, seems to start and run better than the factory setting of 2.
- m37jarhead
Re: TUNE UP S[ECS
Bob:8543bob wrote:GOOD MORNING,
THANKS
BOB
While you're at it, wouldn't hurt to re-check the valve lash, as we old timers used to call it.
Do a search on this subject. There's hot and cold settings, different than the TM's.
JB
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
Past Pres
Member: MVPA #26600
Member: NRA
Re: TUNE UP S[ECS
THANKS ALL.
i will ck the "valve lash" and set the ignition system with the new parts, hopefully she will run like she did before SANDY
AGAIN THANKS
BOB
AGAIN THANKS
BOB
- m37jarhead
Re: TUNE UP S[ECS
Bob:
FYI, I did a search on this site, "valve adjustment."
Charles says adjust cold, 10 thousands for intake; 13 thousands for exhaust.
Forget what the TM says.
JB
JB
Past Pres
Member: MVPA #26600
Member: NRA
Past Pres
Member: MVPA #26600
Member: NRA
