Is there something that sets the friction on the choke cable? Every time I drive, the choke slowly comes on. Driving me batty! There has to be something that stops this?
-jim lee
Slippy choke
Slippy choke
- Site Admin
Re: Slippy choke
You have either no drag on it or the cable is set past the choke lever's rest position, I had the latter problem and realigning the cable's home position to the choke levers resting off position fixed it.
MM
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
