gauge bezel color
Gerry
gauge bezel color
Post by Gerry »
Were the bezels on the gauges painted O.D. or left the metal color when they left the factory?
Gerry
53 M37
sturmtyger380
Re: gauge bezel color
Post by sturmtyger380 »
I am sure no extra effort was made on the assembly line to paint gauge bezels.
But all the paint was a standard color so the bezels would have been very close to the color of the truck.
So if you got some replacement gauges from the 1960's the colors will be different. So if it bothers you that you have a mix match of gauge bezel colors then you might want to mask the faces with blue tape, take a razor knife and run it around the edge, pull off the excess blue tape, mask off the back and paint with your body color.
Hi Gerry,
I'm pretty sure the gauge bezels were painted OD by the gauge supplier before they arrived on the assembly line. I've collected a number of brand new NOS gauges, including a speedo or two and the bezels are all painted OD. I might even go so far as to say the bezels were painted BEFORE they were crimped onto the gauge bodies at the manufacturer, as I can see no indications of masking or overspray anywhere on the gauge faces. The paint simply ends at the end of the bezel. How they got the paint to not crack and pop off when the bezels were crimped over the gauge body is anybody's guess. Check out the edges of the bezels in the pics below......definitely painted before assembly if you ask me.
DSC03664 by w30bob
DSC03663 by w30bob
DSC03658 by w30bob
DSC03656 by w30bob, on Flickr
Gerry
Post by Gerry »
Excellent info thanks guys
Gerry
53 M37
m37jarhead
Post by m37jarhead »
sturmtyger380 wrote:I am sure no extra effort was made on the assembly line to paint gauge bezels.
I just re-did my gauges a few months ago. Stole some plastic caps from my wifes collection that matched the i.d. of the bezel.
Found one that was a very tight fit. Masked off the back of the bezel with blue tape. Shot the bezel with new paint, popped
the cap. Looks pretty darn good with little or no over spray on the lens.
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
