Carb Studs?
knattrass
Carb Studs?
Post by knattrass »
Picked up the int/exh manifolds. I needed to remove the carb studs to install the primer needle valve on the inside edge of the intake. The nozzle has a Tee that wouldn't swing clear of the stud. The stud intake side is a coarse thread, then a small shoulder, then a fine thread for the carb nuts. Is this a standard stud available locally or a special gizmo?
It's a "standard gizmo" that should be available at any decent parts store or the parts department at your nearest auto dealership.
knattrass
Post by knattrass »
Carb side measures 3/8 x 24 and the manifold is 3/8 x 16. I'll see if NAPA has something close unless someone has another source?
knattrass
Post by knattrass »
Got them right off the shelf at NAPA.
I figured you'd be able to get 'em at NAPA. Nice to be able to do that, isn't it? :)
