Allen, some pictures of the front mount for you, it should work with the 360 assuming it dosen't foul the oil filters position (I think the 360's have it at the front??) Also, it has a part?? number cast into it - 1926743 - A
Regards - MM
My Spare Bracket (wasn't keen to pull the main one out just for a picture shoot )
Passenger Side (per left hand drive truck, Mine is right hand drive)
Yep, easy mount, just put a thin rubber mount under it and on the front crossmember, a couple of holed drilled right through and open up the lower holes to 1" so you can get a socket in there to do up the nylock nut you're going to put on your grade 8 mount bolts
I am not good at prices. It is left over from my v8 install & I do not need it. I am in St. Louis MO, so you shipping should not be to bad. I am out in the Dodgemah hall working on my junk so I do not check this page or e-mail often. Call me at six three six 946 0656 & I'm sure we can work something out.
Curious as to what dodge vehicle that mount came from. I too like the idea of using that set up if I ever decide to convert my M-37 to a v-8. Can anyone tell me?
