Differential companion flange torque
Gerry
Post by Gerry »
I cant find the torque value for the flanges on the front and rear Differentials. Finally got time to put drive shafts on but cant tighten the flanges without torquing :(
Gerry
53 M37
Frank Irons
Re: Differential companion flange torque
Post by Frank Irons »
I believe it is 250 ft lbs
Frank
Gerry
Post by Gerry »
I thought the manual said 300 but that seemed like a lot so I wasnt sure if I was reading wrong.
Gerry
53 M37
Frank Irons
Just checked my manual and you are correct, the torque should be a minimum of 300 ft. lbs. per TM9-8031. So much for my memory.
Frank
Gerry
Post by Gerry »
Frank,
Thanks for the info. It was confusing to me reading the manual since they have so many flanges.
Gerry
53 M37
