My new oil pressure relief valve is a spring and piston - the shop manual shows the same part. My T245 doesn't have enough depth for the piston and spring - looks like it had a spring and a ball, but it has been so long I don't remember (and I probably lost the original parts).
What's the story? Two different types?
T245 oil pressure relief valve
Paul Anderson
Re: T245 oil pressure relief valve
Can you post some close up photos ? Maybe it help to see the situation you are dealing with.
- m37jarhead
This may sound like a stupid question but....Since you can't find the old parts, Is the old piston still in the block?
That would sure keep you from installing the new piston and spring.
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
Past Pres
Member: MVPA #26600
Member: NRA
Yep, turns out the old one was stuck in the block - I thought it had fallen out, but obviously not! I used a screw extractor to get it out.
Paul Anderson
