Ammeters, Part # CC- E- 48458-M
I know these are not M37 meters but they show a Chrysler number, and an early patent date, Oct. 7 '19. Anyone know what ther are supposed to be used for? My friend Clark has about 50 and gave me 9 of them. I checked to see if they were for the WWII WC but numbers don't match and I don't have any other barts books to look in. Thanks.
Re: Ammeters, Part # CC- E- 48458-M
Hello,
Can you post a photo showing the bottom of the dial face completely?
It is a panel flush mount unit normally found in a electronics panel, radio or test set.
They show up a lot in aircraft old NOS stock where they were commonly used in test sets.
http://www.wbparts.com/rfq/6625-00-384-8509.html
6625-00-384-8509 Request for Quote Plus Technical Data
Manufacturing Part Numbers under this NSN: 10688, 10688A, 4011, 4015-190, 66741, 9717A, A10101, E48468M, K10688, K9717
http://www.warbird-parts.com/invent/gauges.html
S-561 Ampmeter, -30 to +30 amps, mfgd. by Chrysler, P/N 1-PT-E-48468-M, brand new $ 35.
6625-00-384-8509 Characteristics Data
MRC Criteria Characteristic
AMQY INSTALLATION DESIGN PANEL
APSN (NON-CORE DATA) PANEL FOR WHICH DESIGNED NONMAGNETIC
BHSX (NON-CORE DATA) CIRCUIT CONSTRUCTION TYPE NONELECTRONIC
AMKD INDICATOR TYPE DIAL W/POINTER
BHMW MEASUREMENT RANGE -30.0 TO 30.0 AMPERES, DC SINGLE INDICATOR SINGLE RANGE
APPN ACCURACY IN PERCENT -8.0 TO 8.0 AT FULL SCALE SINGLE INDICATOR SINGLE RANGE
BHDC SCALE GRADUATION TYPE LINEAR SINGLE INDICATOR SINGLE RANGE
ABWG SCALE DIVISION QUANTITY 12 SINGLE INDICATOR SINGLE RANGE
ASSS POINTER COLOR WHITE SINGLE INDICATOR SINGLE RANGE
APMM DIAL SCALE MARKING COLOR WHITE SINGLE INDICATOR SINGLE RANGE
AQFY BACKGROUND COLOR BLACK SINGLE INDICATOR SINGLE RANGE
AQEC MOVEMENT TYPE MOVING COIL, PERMANENT MAGNET
CTQL MOVEMENT SUSPENSION METHOD JEWEL PIVOT BASE
CTTD CIRCUIT ATTACHMENT METHOD AND QUANTITY 2 THREADED STUD
ANTG SENSITIVITY RATING 46.0 MILLIVOLTS
BLSB SCALE SELECTION METHOD TERMINAL
AWZJ POWER SOURCE EXTERNAL
AACT CIRCUIT CURRENT FOR WHICH DESIGNED DC
STYL STYLE DESIGNATOR C1 ROUND FLUSH MTG
APSW METER BODY DIAMETER BEHIND MOUNTING FLANGE 1.954 INCHES MINIMUM AND 2.037 INCHES MAXIMUM
APST METER DEPTH BEHIND MOUNTING FLANGE 0.656 INCHES MINIMUM AND 0.979 INCHES MAXIMUM
ADAV OVERALL DIAMETER 2.625 INCHES MINIMUM AND 2.656 INCHES MAXIMUM
ABHP OVERALL LENGTH 1.479 INCHES NOMINAL
AXHR MOUNTING FACILITY TYPE AND QUANTITY 3 UNTHREADED HOLE
ABTB MOUNTING HOLE DIAMETER 0.144 INCHES MINIMUM AND 0.175 INCHES MAXIMUM
ANRL MOUNTING ARRANGEMENT STYLE E5 THREE HOLE/STUD BOLT CIRCLE
AFFL MOUNTING BOLT CIRCLE DIAMETER 2.374 INCHES NOMINAL
NHCF NUCLEAR HARDNESS CRITICAL FEATURE NONHARDENED
CBBL FEATURES PROVIDED ZERO ADJUSTER
ZZZV III FSC APPLICATION DATA TEST SET, ELECT. EQUIP.
Thanks Wes;
Intresting, Clark found them at a scrap yard where they were headed for the shreader and gave the owner $5. for all which was 3 five gallon buckets full of them.
There should be an adjustment opening on the back.
No adjustment opening on the one that I opened, haven't unrapped any of the others.
Carter those are pretty cool gauges. THere has to be a story behind them.
A story I'd like to hear other than what I know already which is they came from Mechanicsburg Pa. Naval Ship's Parts Facility in a Property Disposal bid sale years ago. Now I need to figure out what to do with them.
Advertise them on the radio operator's and radio equipment web sites.
Also on the vintage car and hot rod sites. I'm sure they'd love the logos and Chrysler markings. OR just hit all venues at once by putting them on E-greed.cuz wrote:Advertise them on the radio operator's and radio equipment web sites.
What sites do you guys think would be best as Clark and I would like to sell some of these.Joe wrote: Also on the vintage car and hot rod sites. I'm sure they'd love the logos and Chrysler markings. OR just hit all venues at once by putting them on E-greed.
I wonder where they were made. The backward "C" in Chrysler seems to indicate that they were not made in the U.S. An error like that should have been caught and corrected immediately if they were.
Only one box has the typo backwards "C". And then only on the rubber hand stamped boxes.
