I don't have my manual CD with me, does anyone know if the starter breakdown/rebuild is in the manual? Mine works... just a little sluggish and seems do draw a good bit of juice, I am thinking the bearings may be in marginal shape. Would rather not send out to rebuild for a big bill if I can just disassemble, clean and replace what needs it.
Thanks for any info.
Mark
Starter Manual
Starter Manual
Mark Ellis
1953 M37 WOW
1967 M101A1
USMC Retired
1953 M37 WOW
1967 M101A1
USMC Retired
Re: Starter Manual
The ORD 9 gives you the parts list and illustration. The TM 9-1825B gives you the overhaul and test specs. The 8030 only gives you the switch adjustment and the pinion adjustment.
