WTB winch studs
Gerry
WTB winch studs
Post by Gerry »
I am looking for the studs that go on the ends of the winch to mount to bracket.
Gerry
53 M37
Re: WTB winch studs
Gerry wrote:I am looking for the studs that go on the ends of the winch to mount to bracket.
McMaster-Carr has them all.
Gerry
Re: WTB winch studs
Post by Gerry »
Thanks Charles
Gerry
53 M37
Gerry
Re: WTB winch studs
Post by Gerry »
I tried McMaster-Carr and they dont have them. Anybody got any other ideas. I tried midwest and VPW with no luck
Gerry
53 M37
Re: WTB winch studs
Gerry wrote:I tried McMaster-Carr and they dont have them. Anybody got any other ideas. I tried midwest and VPW with no luck
You must have looked at the wrong place, or talked with the wrong person. We buy from them frequently. They have them.
Can you send me the dimensions; I'll help you out.
Gerry
Re: WTB winch studs
Post by Gerry »
Thanks Charles,
I looked online and called with no luck.
9/16 –18 NF(7/8) x 9/16-12NC (7/8) x2 5/16
Gerry
53 M37
Re: WTB winch studs
Gerry wrote:Thanks Charles,
PM sent
powerwagontim
Re: WTB winch studs
Post by powerwagontim »
Charles,
Others are looking for these studs too, at least I am! Does McMaster Carr have them or do they not?
Tim
Gerry
Re: WTB winch studs
Post by Gerry »
Tim,
Here is the info I ended up with from Charles. I actually just installed them in the winch yesterday and they look good. Wont be putting on my truck for a while though,Well it appears McMaster-Carr has stopped furnishing these. Their stock now jumps from 1/2" to 5/8" on diameter.
"I looked back in my files; what we did last time was from Dorman. Their local jobber is CarQuest Auto Parts. The part number we use is 675-046. This is a box of 10, grade 8 studs. They are slightly longer at 2 1/2". I looked at a winch we had at the shop this afternoon and the studs in it are actually too short, so these may be closer to what you need anyway as far as length. If they do come up a little long, you can just grind the ends off after assembly. This part# will get them at CarQuest; "
Thanks again Charles,
Gerry
53 M37
Re: WTB winch studs
powerwagontim wrote:Charles,
Tim
McMaster-Carr is apparently no longer offering this type of stud was my finding when I checked some weeks back. We did find them at the local CarQuest with whom we deal a lot; under the Dorman Product line.
powerwagontim
Re: WTB winch studs
Hi Charles,
Thanks for the lead on the Dorman products. Do you have the part number you used? I checked with my local parts guys today, the closest thing they could find was a stud 2 1/2" long, and coarse thread on both ends as opposed to the correct coarse / fine mix at 2 5/16" long. (I figured 2 5/16 would be tough to find, but 2 1/4" would be fine) The number they gave me for the 2 1/2" stud (coarse x coarse) is 675-046
Tim
cuz
Re: WTB winch studs
Post by cuz »
This will put all the info in one place:
http://www.dormanproducts.com/p-16195-675-046.aspx
675-046 Double-Ended Studs Grade 8
"A" Thread Size : 9/16-12
"A" Thread Length : 3/4"
"B" Thread Size : 9/16-18
"B" Thread Length : 1"
Shoulder Length : 3/4"
Overall Length : 2-1/2"
Brand : Dorman - AutoGrade - Boxed
powerwagontim
Re: WTB winch studs
Thanks Cuz,
My parts guy must have read it wrong. I have 6 on the way for pickup tomorrow.
Tim
Gerry
Re: WTB winch studs
Post by Gerry »
Tim,
Do you have 2 already? You need 8 studs total.
Gerry
53 M37
powerwagontim
Re: WTB winch studs
Hi Gerry,
So much for my memory! I will let them know tomorrow I need 2 more. Thanks for the reality check,
Tim
