hydra boost
scottc
hydra boost
Post by scottc »
I am getting ready to put in a gm hydra boost M/C set up but I am cannot decide whether to put in hanging pedals or put it where the orig mc is at?? Any advice?? I have done lots of measuring and it will fit just would have to put in a access pannel under the drivers seat to fill the mc.
SOTVEN
Re: hydra boost
Post by SOTVEN »
IN MY OPINION, PUTING HANGING PEDALS WILL GIVE YOU 2-3 INCHES MORE LEGROOM. THIS IS HOWEVER IF YOU CHANGE THE CLUTCH PEDAL ALSO. GOING WITH THE ORIGINAL SETUP WILL BE LESS WORK AND PERHAPS LESS EXPENSE. SO IF YOU DO NOT NEED THAT ADDITIONAL LEGROOM, I WOULD GO WITH THE ORIGINAL SETUP LOCATION. GOOD LUCK :)
