E-brake band size.
Gerry
E-brake band size.
Post by Gerry »
Does anyone know the thickness of the e-brake band. Re installed with a new band (believe they used 1/4 inch)but I cant get the open end to close enough to put the screw in. Or am I doing something wrong.(which is very possible)
Gerry
53 M37
Re: E-brake band size.
Gerry wrote:Does anyone know the thickness of the e-brake band. Re installed with a new band (believe they used 1/4 inch)but I cant get the open end to close enough to put the screw in. Or am I doing something wrong.(which is very possible)
The correct lining material is 1/4" X 2" wide, must not be doing something right.
Gerry
Post by Gerry »
Thanks charles. at least now I know the band is right. Busy working the weekend. Hopefully have some time next week to look into it more.
Gerry
53 M37
SOTVEN
Post by SOTVEN »
PERHAPS THE BOLT THAT YOU HAVE IS NOT THE ORIGINAL, RATHER A SHORTER ONE? I DO REMEMBER THAT BOLT BEING QUITE LONG ON MY TRUCK :?:
Gerry
Post by Gerry »
I thought the same thing but I looked in the manual it it was the right lenght. but i will double check again because a longer bolt would work.
Gerry
53 M37
