thermostat
TOM R
thermostat
Post by TOM R »
guys is there a napa # for the thermostat so I can replace it tommorow when i am workin on the heater, thanks :D
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
M-Thrax
Post by M-Thrax »
Don't know if these NAPA #'s are still good but #55 is a 160o stat and #155 is a 180 stat
N1VSM
Mechanical t-stat thread hijack
Post by N1VSM »
M-Thrax wrote:Don't know if these NAPA #'s are still good but #55 is a 160o stat and #155 is a 180 stat
Does anyone know if there is a mechanical t-stat sender that will fit? I'm having electrical problems with mine that might be more easily fixed by a change in system. Did that with the oil pressure gauge & can finally rely on the readings.
You must be referring to the sending unit for your temp guage. They are all electric and easily available. Thermostats don't have senders. They're mechanical valves that open as they warm up. They are manufactured to begin opening at specific temperatures. A 180 'stat will begin to open when the coolant temp reaches 180 degrees Fahrenheit. Same goes for 160 or 190 'stats.
Re: Mechanical t-stat thread hijack
A mechanical temperature gauge is available from various sources. It has a tube with fittings that screw into the block where the original electric sender was, this tube is permanently attached to the gauge. No electronics are involved except for lighting. They are available with different tube lengths so you can chose the best suited one for the application. The gauge face doesn't match the military pattern, so if you desire the original look, this solution won't work for you. If originality isn't an issue, you can easily acquire a mechanical gauge from NAPA, etc.
