Looks like 5 full twist, then pop went the Foote Long Axle
W_A_Watson_II
Post by W_A_Watson_II »
WARNING: The Picture links to a VERY Large Image: http://m37.wawii.com/images/DSC05631_M3 ... ngAxle.JPG
Well, I broke a long rear Foote Axle the afternoon before a trail ride! Looks like 5 full twist before it broke. I was able to swap out the broken axle for a stock one in just over an hour and was ready for the Memorial day Trail Rides.
I was lucky the broken end came right out with a magnet (after pulling the center section). I did pull the center section out to be sure there were no other damage and any broken pieces left in the axle housing were removed.
I was in the Ozarks and pulling my Sister-In-Laws car back on the road after an accident when it let go. I was NOT using the lockers, but was up on all four on a gravel road in 4WD low, it let go with a pop.
After puller her out I loaded up and drove the 90 miles to my brothers shop so I had a floor jack and a patch of concrete (the shop was occupied with an 18 wheeler with out a drive shaft).
Not sure why it let go, or that all the twist damage was from this one event. Any suggestions or ideas?
On the Trail Riding, well Gabrielle (just turned 10) had a blast, except for the extreme trails). It was another great weekend with Daughter, M and Friends.
Will
Will
1946 Dodge Power Wagon
My 1953 Dodge M37 WEB Site
Josh
Re: Looks like 5 full twist, then pop went the Foote Long Ax
Post by Josh »
I would guess it has been twisted for a while and finally just fatigued, based on the fracture surface.
This is nature's way of telling you you need Dana 60's Will... :wink:
Glad you were able to easily effect repairs and still get in that ride :)
W_A_Watson_II
Will
