Lots of parts that need a new home
Brett
Post by Brett »
I have parts from 2 different 52 m37's. I'm going to swap out my 230 for a v8. and I have some remnants from my parts truck that I would like to see go away. So I have for sale
original engine (was running but low compression)
intake & exhaust manifolds
Good starter
2 generators (don't know if they work but looks ok)
mechanical voltage reg.
solidstate voltage reg.
Original fuel pump (Was working, but would definitely rebuild)
Carter BBS Carb (not original but will run on 230 also should be rebuilt)
Original military Dist. with 6 original wires (was running appears good)
oil filter housing
Original early trans (I had the top cover off of this to inspect it and everthing seemed tight. Also have driven it, and it ran through the gears nicely. was rebuilt by the army in '72)
Clutch flywheel and pressure plate
original transfer case from my parts truck (seems ok)
Fairly complete chassis from parts truck. (rear diff and Axle shafts are gone, and I'm probably gonna hang on to the front axle, But everything else is fair game)
Remnants of Cab from parts truck (I have started to cut parts off of it for repair But cowl and dash areas are pretty good as well as other areas)
Misc. 24v guages of unknown conition
There's more stuff I'm sure I'm just forgetting so ask.
Make me an offer on what you want I'm very reasonable. I'm willing to ship, but no I don't know how much its gonna cost to ship it. But, if you come pick something up, you might find some other stuff I haven't listed yet because I just haven't decided if I'm gonna keep it or not.
BTW I can send you pics if wanted
thanks
Brett
snowdad
Post by snowdad »
Brett,
PM Sent. Can you provide pics of engine if not too much trouble?
Brett
Post by Brett »
Fuel pump spoken for
Brett
Brett
pics
Post by Brett »
I've added some pics to my gallery here under Brett Bunnell. Heres just a couple.
If there's something you're interested in Make me an offer!! I don't really know what this stuff is worth. BTW everything is located In Murfreesboro,TN Just outside of Nashville
Brett
Brett
Post by Brett »
I've sold some stuff, but I still have more to sell
These are no longer available
Parts cab
Dist, plugs, wires
Fuel pump
Int& exh Manifold
I still have a lot left
Rebuildable engine
Clutch
Good trans
transfer case
Generators and regulators
Chassis and suspension parts
Alot more, just ask
Brett
Brett
Still have some stuff
Post by Brett »
Still looking to get rid of some of this stuff. I've bought a donor vehicle for my V8 swap and I need room in the garage. I thought I'd throw some prices out and see if that helps. I'll still listen to offers as well.
Engine $100
Trans $100
2 generators 1 mech reg 1 SS reg 2 cables $40
Good starter $40
Drop me a PM if you have any questions. I'm willing to ship, but I may charge a little extra to crate up the big stuff.
Brett
52m38
Re: Lots of parts that need a new home
Post by 52m38 »
Hay Brett, Brett here. I'm looking for E-brake band and all the hardware to mount it. Do you have any of this stuff ? Thanks. Brett
52 M38
53 CJ3A
53 M37
Brett
Post by Brett »
Brett,
I've got an extra parking brake assembly, but it will definitely need to be relined. I'm not sure how big of a deal that is. Drop me a PM if you're interested.
Brett
8543bob
Post by 8543bob »
Hi,
I'm looking for a bellhousing from the 230 engine. Please let me know if you got. 347 200 3015.
Bob
goodtimejonny
Post by goodtimejonny »
Do you have a speedometer cable?
Brett
Post by Brett »
I'm pretty sure I have a Speedometer cable, but I beleive the rubber on the out side of it is not the prettiest. I can send you a pic tomorrow if you want.
Also I didn't realize I never up dated this. But I have sold alot of parts. The eng & trans are gone, as well as the cab. I do still have a transfer case, a windshield frame that is salvageable, a couple of radiators, some front end sheetmetal, and lots of odds and ends, so just ask.
Brett
powerwagontim
Post by powerwagontim »
Hi Brett,
Do you still have the electronic voltage regulator?
Tim
Brett
Post by Brett »
Tim,
Sorry but the regulators and generators have been sold as well.
Brett
Do you have a good driver and passinger doors?
Brett
Post by Brett »
I have a fixable Driver's door. It looks like it made pretty good contact with the front fender. There is a pic of the bottom edge of the door in the photo gallery under Brett Bunnell. The door is pretty solid other than that. I'm planning on using the passenger door off of that truck, and it looks pretty much the same. let me know if you're interested
Brett
