Front and rear spring questions
I have one t/o front spring leftover from redoing my entire front end a few years back. I also have a couple of broken right-rear spring leaves, and my question is: Can I use some of the front spring leaves to swap in to replace the broken rear leaves? They appear to be the shorter leaves, though I haven't counted to see exactly which leaves they are.
I'd rather not order an entire spring even though I know they are available-I shudder at the cost they might bring at today's prices.
Any expertise, as always, is appreciated!
hbb
Post by hbb »
Gary;
I have had quite a bit of experience with mixing and trying to match spring leafs but the end results are always the same. It doesn’t work; one side will be higher than the other. That is one job to take to a spring shop and let them do it right or find a set from another truck that are in good shape. Call around you might be surprised it in not all that expensive to have them rebuilt.
hb
SierraM37
Spring Shop
Post by SierraM37 »
I agree with Gary. I took mine to a local shop, had them add some leaves and re-arch them to gain about 2". New bushings and sleeves. She sits pretty and level now.
Todd
'52 M37 W/W
'52 M37 WOW
'01 Dodge Durango
'07 Jeep Rubicon (JK)
Thanks for the responses, guys. I suspected it might be easier to have a spring shop do them, or just replace them altogether. I'll explore those options and see what works best.
SierraM37
Post by SierraM37 »
Gary - I'm going to have to come visit next time I'm down in the Santa Cruz / Monterey area.
Todd
'52 M37 W/W
'52 M37 WOW
'01 Dodge Durango
Sure Todd! Send me a PM when you're going to be in the Monterey area.
