Does anyone know the Qty. of each length to make the fixed lengths work?
Is it better to buy a spool (where) and cut/flare myself?
What did you use for the flex lines to both front and rear?
Does it matter if use 5/16th or 1/4?
Lastly, what about the brake light switch. Does anyone have a model # they used?
Thanks in advance guys. Hoping to have on the road this spring early summer.
