Added a dome light
Added a dome light
My M37 is currently my daily driver due to a DA driver in ATL crushing the wife's G35 (all okay). This has left her driving my 1997 Tahoe and me in the M. I am not complaining but I did find myself needing a domelight. Saw on SteelSoldiers where the guys were putting dome lights from armor in their M35s so I went for it. NOS lights go for $79 but I found this one used on ebay for $18 shipped:
Carmen,
My truck's wire was butchered when I got to it. I did a "functional" restoration on it making it safe and reliable to drive. To this end, I did a complete rewire on my truck. I put in a ENOS fuse panel (many companies make a comparable panel with modern blade fuses) and I wired the positive side to the dome light terminal on the fuse block. I used two conductor lamp wire to do this as I wanted to include a ground wire. The ground wire I secured to one of the mounting fasteners for the fuse block. Ran the wire down through the vertical center windshield post with grommets. Light has the built in switch shown with one way turning on the blue light to save your night vision. Pushing in a lockout button and turning the switch the other way turns on a bright white light that illuminates the whole cab. Bill
- CPL
Looks like the word is out and the Bill might have started a run on the lights - time to buy some stock in overhead dome tank lights.
http://cgi.ebay.com/military-tank-dome- ... 4a9d92ea24
Jim
Jim
- SSGT
the way the roof curves down and connects with the top of the window frame on an M43 creates the perfect spot for a linear LED light for the cab. It's hidden from sight and most LED fixtures are 24v already. I'll control mine with a discrete switch under the dash somewhere. I'll post some pics eventually!
1953 Dodge M43
Fail often to succeed sooner
- HingsingM37
