Master Cylinder
Master Cylinder
Guys,
I wish to upgrade to a dual circuit master cylinder, I think. Does anybody have a NAPA or other number for a dual circuit MC for 4 wheel drum brakes with a residual pressure check valve built in? The article in MV magazine gives a number but it is for the front disc conversion. I am replacing the entire system, lines, hoses, wheel cylinders, I could keep the original single circuit style also? The dual set up is of course safer, but the original is less greif to install. Of course I stripped my whole truck down to the bare frame, so drilling new holes and a few mods cant be too challenging at this point LOL. Insight and thoughts please. Thanks. :)
Talking to myself LOL.
David,
After 103 views nobody had an answer to your post so I did so research and your are going to use a NAPA#TS 101405 which is for a 1970 3/4 ton four wheel drum, non-power brake system and has an internal residual check valve . You will advise everybody how this goes. Good Luck. :?
SOTVEN
Post by SOTVEN »
Hello Hingsingm37. I was 1 of the 103 who read your question. Unfortunattely there is no way in this life I could answer it, since there is no such thing as Napa in Greece, or anything as such. Hence I did not post a reply. I guess all the others did not reply because they did not have this information and only for this reason. In any case, good luck with your project. Happy New Year. :D
Stoven,
I figured maybe nobody wanted to answer my brake question fearing a "liability" issue LOL. :roll:
What? No NAPA Auto Parts in Greece? I thought there was a UN Mandate that all countries on earth have a chain of NAPA stores and Steak and Shake restaraunts. Happy New Year friend :D
rixm37
Post by rixm37 »
How about the Ugly trucklling web site they show a conversion to a dual m/c while doing a disk brake upgrade.
http://www.uglytruckling.com/
Here's the link. I am thinking of doing the conversion to my truck using their steps and parts for the Chevy 1 ton. 8)
Thanks. Will do. :)
SydneyM37
Re: Brakes
Post by SydneyM37 »
HingsingM37 wrote:David,
would this part be suitable still if a hydrovac booster was installed ?
Bruce
Keep em green to keep ya keen
SydneyM37,
I do not know if it could be adapted. That part # is for a early 1970's civilian 3/4 ton with 4 way drums. :)
Monkey Man
Site Admin
Site Admin
Vacuum Booster.....
Post by Monkey Man »
G'day David, I run a VH80 booster on my truck and when it was drums all round it worked fine, the main pull to the disc brake upgrade is was the cost of getting drums here as mine were getting out of service (or so I thought anyhow) so with the kindness and help from Ray, Brigand and others I have the 4 wheel disc conversion on mine and I'll go to the dual circuit master cylinder conversion in winter minus the booster I have, you are welcome to it but I am sure you can find something locally for a few $ only. I can take some pictures if you like to give you an idea as to how it was done....
Take Care
Best Regards - MM :-)
Trained Monkey on Guard
dodgem37@netspace.net.au
MM,
Some pics of the M/C install would be great. :D How did you do your brake light switch?Thanks for the offer on the part. I fear the shipping would be cost-prohibitive :cry:
