Help!
http://www.g741.org/photogallery/main.p ... =x13657881
g741.org
M37 Discussion Forum |
Hi David, rainy here on a Saturday, so I had a little computer time this morning.HingsingM37 wrote:Ok guys, so after assembly and 4.5 years I have these two gems leftover. The one is a hasp similar to the one on the battery box but for the life of me I can't recall where it goes?The other appears to be a 45 degree angle bracket that may be for a spring? Although I have the brake and clutch springs attached to L shaped brackets which attached to the frame. Although this bracket looks as if it may be for two bolts? Some type of little brace? The hasp did come off my truck as it has the Dodge fasteners and is the same Fire Engine Red my truck was.
Help!
