Montana, if you have some time, a grinder, and a few hacksaw blades, you can make these:
I recommend making the one on the bottom, it is most useful.
Get a VERY small screwdriver stick it in the edge of the key slot, and twist it lightly to put a little side pressure on the pins. then, stick the rake in and just rake back and forth, you'll feel when you get one popped up. the side pressure will hold it up, then move on to the next. I recommend starting at the back of the lock and moving forwards, you're less likely to knock loose the ones you've popped up. this is the same thing a locksmith is going to do, and will be much cheaper; not to mention, its a thrill to pick a lock James Bond style!
I've picked my house door, as well as a neighbors door this way (we both locked ourselves out).
