UPS man brought me my lockout hubs!
refit1701
Post by refit1701 »
I got my lockout hubs yesterday and they are beautiful. These are from Dan and are the Warner design.
Definitely great workmanship and I will try to put up a couple of pics late today.
-John
Member of Dixie Division MVC
1953 USAF M37 wow, restored
1953 USMC M37 w/w -in storage
1967 M116A1 Pioneer Trailer
S-89 Comm box
BILL L
Post by BILL L »
I painted mine to match my truck and so far the paint has held up good.
Another Christmas package! Enjoy! I run the Superwinch lockouts-I know, not as durable, but I got them at a great price from John Bizal a few years back.
Re: UPS man brought me my lockout hubs!
refit1701 wrote:I got my lockout hubs yesterday and they are beautiful. These are from Dan and are the Warner design.
Who is this Dan you speak of? Is there a website you can direct me to?
refit1701
Post by refit1701 »
http://www.powerwagonlocker.com/
Look to the left under power wagon hubs.
-John
S-89 Comm box
refit1701
Post by refit1701 »
I started to install these last night and discovered how difficult the original hubs are to remove. I must have worked on one for 45 minutes and it's still not off!
I've got to get a puller. It only has to move another 1/4 of an inch and it's off.
Wow.
-John
S-89 Comm box
Thanks for the prompt reply. I will check the site out.
monkeymissile
Post by monkeymissile »
got to start saving my pennies, those are very nice looking and I think the Warn design is the best (and best looking)
1953 Dodge M43
Fail often to succeed sooner
John,
If you have the stock drive flanges they should practically fall off once the nuts are off and the paper gasket is torn. Odd one should be so hard unless something is amiss? The original flange has two threaded holes to use as puller bolts. Do you have the original flange or somebody else's hubs on there now?
Make sure the hubs aren't cock-eyed and binding up. If not, the puller bolts should free them up. Apply some torque evenly to the puller bolts then rap the hub from the side-that might spring them loose.
powerwagontim
Post by powerwagontim »
John,
As others have spoken about removing the drive flanges, I dont need to add to that, but if you are pulling a lockout hub, make sure the transfer case is in neutral. I fought getting a hub off once until someone told me to put the TC into neutral, it almost fell off then. Otherwise, as prevoiusly stated, there might be something broken or twisted keeping it from coming apart.
Good luck,
Tim
refit1701
Post by refit1701 »
I finally removed the old hub using some longer bolts. The splines seem ok. I now have to remove the studs but they don't look removable. Check out the pics.
I started with two nuts jammed together but the force I'm putting on them trying to turn the stud seems excessive. Is there another way to do this?
Pics below:
-John
S-89 Comm box
powerwagontim
Hi John,
Thats the right way to do it. You are probably already doing it but be sure you are wrenching on the lower nut, forcing it against the upper one. If all else fails, and you cant save them, a small pipe wrench will spin them out.
Good luck,
Tim
Good Looking & Tough Too!
Nice going John, I'm guessing you finished up?
refit1701
Post by refit1701 »
Thanks Tim.
I haven't finished yet, Bruce. I am putting these on to make it easier to roll the chasis in and out of the garage. My buddy is painting some of the body at his shop but I am still cleaning and fixing on the frame/powertrain.
I'm also still working on the cab.
-John
S-89 Comm box
