Any pointers on disassembly? Bed, cab, engine in that order?
The Adventure Begins
Okay guys I started in this hobby with the M151's and have spent a considerable amount of time on the wwwg838. org board. I'm real close to completing that project so I decided to start my next project. I will be spending more time here picking your brains as I get into this restoration. I will also post photos of my progress.
I'm going to drill the heads off the screws in the bed. So is it easier to remove the bed as one piece and than take it apart on the ground?Front Clip, then the bed (you can remove as one piece or break down to sides and front rear and floor...a lot of screws to remove) cab. Then engine, trans etc.
Thanks for the compliment on the mutt. It turned out nice and I didn't use any body fillers just a very little spot putty in a few areas.
