Gas Tank RENU
churtle
Gas Tank RENU
Post by churtle »
gOOD MORNING Y ALL, OK THE QUESTION I have is where would one get his gas tank renu'ed or repaired at ??? Radiator Shop or do I need to look for someone specific??? TIA
There are places that specialize in gas tank repair, but they can be hard to find. Most radiator shops can also handle the job.
TOM R
Post by TOM R »
my 46 jeep gas tank has a tag on it from this company and I have had no problems so far and the tank was modified before coating :D
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
JBizal
Gas Tank ReNu Company
Post by JBizal »
Do a search on the net for this spelling. They have franchise operations all across the US. They offer a lifetime warranty when it is coated inside and out. Once it is coated, the outer surface is paintable.
John
Paul (in NH)
Gas tank coating
Post by Paul (in NH) »
There was a company I found out of NJ, I think. I had my M-38 tank boiled and coated at the local radiator shop. Cost me about $300, I thought a little high, but what are you going to do?
TOM R
Post by TOM R »
sorry forgot to post the link http://gastankrenu.com/how.htm :D
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
knattrass
Tank Connector?
Post by knattrass »
Got mine RENU'd, pretty ugly. They had to cut 2 holes, one on each side of the baffles, shot peened it, welded, and coated inside and outside with a very thick black coating. Put the tank in, and found a leak right at the rear drain plug - forgot to solder. Be sure to have them check that!
The local parts store sold me a 6" Goodyear radiator hose for a replacement to connect to the filler pipe. Doesn't sound right to me? Seems like there would be a fuel line hose? :?:
Re: Tank Connector?
knattrass wrote:Got mine RENU'd, pretty ugly. They had to cut 2 holes, one on each side of the baffles, shot peened it, welded, and coated inside and outside with a very thick black coating. Put the tank in, and found a leak right at the rear drain plug - forgot to solder. Be sure to have them check that!
There is a correct hose for gasoline application, this correct type hose is available at NAPA. A radiator hose will work for a short time, however will become gummy & start to separate with repeated exposure to gas or diesel bringing with it the usual horrors of hose deterioration.
knattrass
Post by knattrass »
Charles - thanks for the catch. NAPA has the 2 1/4" ID fuel filler hose (p/n 1055) for future reference. My old piece, or what's left of it, looks like 4" length - 2 clamps.
