Fuel Tank!
Tim Powell
Fuel Tank!
Post by Tim Powell »
[img][img]http://i292.photobucket.com/albums/mm38 ... CF6954.jpg[/img]
It took a while but I finally got back around to working on the truck! With a little help from Mr. Bear I've got the fuel tank out and to the shop!
[/img]
Good start keep us posted on the progress please.
I still think it would be so cool if someone made a plastic replacement tank...but that's just me... :)
GERALDO
replacement fuel tank
Post by GERALDO »
That would take all the FUN out of it plus it would probably run around $600 to $800 to produce since the molds are so expensive. I have already done two and getting ready to do another one soon . it cost me $150 plus the cost of the fuel sending unit plus the paint and all the fun of putting it back together!
Re: replacement fuel tank
GERALDO wrote:That would take all the FUN out of it plus it would probably run around $600 to $800 to produce since the molds are so expensive. I have already done two and getting ready to do another one soon . it cost me $150 plus the cost of the fuel sending unit plus the paint and all the fun of putting it back together!
So $150 was RENUZIT's cost or what it cost for you to do it yourself? I hope Mr. Bear is pulling his weight?
GERALDO
fuel tank
Post by GERALDO »
HI BRUCE! no not renews it , they charge to much I think it is around $300 plus shipping , I use a very good radiator shop in Salisbury, N.C. that does radiators and fuel tanks, He cleans the inside and coats it, he also re solders the fittings all you have to do is install the fuel pickup plate and install the sending unit . the last two I had done was $150. well pleased with his work. Geraldo
I didn't even think about a radiator shop, I was leaning toward doing it my self.
Brett
Post by Brett »
I'm in the process of doing my tank right now. I checked with a couple of radiator shops in my area, and they all told me that no one will mess with gas tanks anymore.
So, I decided I'd rather do it myself. I thought my tank was pretty sound, and just had some surface rust. That was until I decided to start cleaning it. I used a serious degreaser that I use at work inside the tank, sloshing a couple of gallons around for a few minutes. I then rinsed it with water 3 or 4 times, filling it completely each time. I then took more degreaser a scubby pad, wire brush, and putty knife to the outside of the tank to clean it. At that point I began to a lot of pin holes in the tank. I noticed a couple while doing the inside too, but more when I started removing all the Oily grime from the outside of the tank. This same stuff was also covering the entire bed floor and aparently had leaked through the inspection cover onto the tank.
At this point I started trying to solder holes in the tank. Plumbing solder and flux that I had in the garage was not working. So, I got some Nokorode Flux, and acid core solder with a realy low melting point, and went to town soldering about 60 pin holes in the tank. They may not be pretty, but they seem to be well bonded. I also decided to look into a previous repair in the bottom of the tank. What looked like a cheesey repair of epoxy putty was concealing a big wad of lead and 5 sheet metal screws. It looked like someone had driven the screws into pin holes, and tried to seal it up with lead, and when that leaked covered it with epoxy putty. But, since they never sealed the tank, water got back into it, and rusted out that whole mess. So, I cut it all out, and welded in a patch of Sheetmetal.
My plan at this point is to line the tank with a product from KBS coatings. It looks like a decent product, and you can get their 3 step system for about $60. I'll also need to bend up a new pickup tube, and come up with a plan for a sending unit.
Brett
GERALDO
fuel tank
Post by GERALDO »
Bret, I think you are throwing good money away on a bad tank! you are just putting off the fact that you need another tank, Im working on a nice tank that is for sale, it will have a new pickup plate, vent and a intank filter, come to aberdeen md, at the show and get it!
