The final thing to re-install after gutting everything out from the flow wheel out to the wheels was the transmission tunnel cover. When I relocated the shift tower hole in the transmission tunnel originally, I was off a little and missed needing to move it upward to allow the shifter boot to be installed. When I pulled the Cover to swap transmissions I discovered that the right side also had rubbed the cover. So I redid the cover completely rather than just moving the hole again. I opened up the original hole to clear, and built new panels to enclose the shift tower, and fir the boot. In order to fit the NP435, I installed the tunnel boot over the transmission boot.
The M is Trail Ready again.
- W_A_Watson_II
http://m37.wawii.com/
Last edited by W_A_Watson_II on Sat Mar 21, 2009 5:06 pm, edited 2 times in total.
- W_A_Watson_II
- W_A_Watson_II
