Found inaccuracy in these heater installation instructions
Nickathome
Post by Nickathome »
http://www.olive-drab.com/od_m37_heater.php3
In case anyone uses these instructions before installing an M151 heater in their M37. Be warned, the instructions mention buying 1/2" NPT pipe threaded nipples, etc. This is incorrect. It should be 3/8ths" NPT pipe thread, not 1/2"....
3/8ths" pipe thread gives you an outside diameter of about 5/8ths inch, which is what you need. 1/2" NPT has an O.D. of about 3/4" which is too large.
I almost bought the wrong items today at NAPA because I listened to what the instructions said. Good thing I took a look at the plugs on my truck's engine beforehand. I knew right away that 1/2 in pipe thread is too large.
It was wise of you to take the plug with you. Inaccuracies can sometimes be found in the best thought-out instructions prepaired by professionals. Whenever possible I also take anything I can to help in selecting the correct part or object and thus avoiding the dreaded second trip to the store. Good move Nick.
Merry Christmas, see you next week.
Nickathome
Xmas.
Carter;
Thanks and Merry Christmas to you and yours.
