Hello every body,
I wish to know the function of the little door, wich is on the hood, very close to the windshield. I have no idea of the function of this door.
Does anybody know it?
Thank you very much indeed
William
little door on the hood
OLDSMOBILE 88 ROCKET 1955
CJ3B MITSUBISHI WILLYS JEEP
DODGE M37
LAND ROVER LIGHTWEIGHT LONG WHEEL BASE SOFT TOP
LAND ROVER LIGHTWEIGH LONG WHEEL BASE HARD TOP
DODGE M37
Its the cowl vent....
If you are referring to the small door in front of the windshield just behind the hood, its the fresh air cowl vent. There should be a lever under your dash board that is used to operate it.
Monkey bone
we must haven been typing at the exact same time
Lever...
Just FYI, the lever for my cowl vent was (I thought) broken off. It wasn't until later, digging under the dash for some wiring or something did I notice it was bent way back under the dash, so if you don't see it right out there, look up under the dash.
This also had me pondering, "What did they stick in the cab/seat that bent that steel rod half-way back like that?!?" no other damage so I doubt it was from any type of accident or anything!
-Dana
Hi guys,
thanks all for the quick answers provided. I don´t think it is working because as I said, this track has non original engine neither dash board, so dont think it is going to vent, but Ill ahve a look on weekend looking for the lever.
Thanks again
William
Thanks again
William
DODGE M37
DODGE M37
