Looking for long shifter shaft - B1?
I'm looking for a long shifter shaft - I think they were standard on the B1 trannys. Not interested in the extension that goes on the short handles.
longer shifter shaft . .
The M43 ambulance used the longer version - that is where I got mine.
Long shifter....
What is the real advantage(othr than being the correct shifter) to the long shifter? My B1 has a short shifter and it is very easy to use. I will admit that when my sons ride with me they have to watch being hit with the shifter when in reverse but I think that would be the case with the long one as well, or maybe not.
Advantage of longer shifter
(1) I find that the shifter knob is at a more comfortable height
(2) The longer handle gives you more leverage - less wrestling into gear
(3) There is a bigger horizontal movement from 1st/2nd to 3rd/4th to Rev. Just more comfy for me, I guess.
Looking for ANY shifter shaft
Ok - no luck on finding a long shaft. Anyone got an extra shifter shaft they are willing to let go for a song?
Thanks, Charles
I'll contact you off-board. Thanks!
Re: Long shifter....
I just found out a little tidbit - supposedly, the long shifter can't be used if you have the NOS defroster duct. I'll repost if I find otherwise.Nickathome wrote:What is the real advantage(othr than being the correct shifter) to the long shifter? My B1 has a short shifter and it is very easy to use. I will admit that when my sons ride with me they have to watch being hit with the shifter when in reverse but I think that would be the case with the long one as well, or maybe not.
None I need to part with.T. Highway wrote:Charles Talbert,
Do you have any long shifter handles left?
Just check out the regular vendors.T. Highway wrote:Do you know who may have one that they do want to part with?
Gary,
I was going to contact him next.
The guy I bought this truck from gave me a folder full of receipts for parts bought from Midwest Mil. John's web site is GREAT.
