TUBES
TUBES
My local tire shop is telling me a 7:50 x 16 tube will work fine in place of the 9:00 x 16. True? :?
Thanks in advance :)
Nickathome
Tubes.....
Post by Nickathome »
Maybe they will, or maybe this place just wants to get rid of something they've had lying around for a long time. Too many times you'll get the old "yeah it'll work". Yeah it might, but why take the chance. More often than not, the place selling the stuff is wrong or it'll only be a marginally effective alternate. I'd tell them you want the exact replacement or will take your business to the guy who has what you need.
Thats what I thought. I looked up some old posts on this topic and the concensus was no.
nivek
HS37.. NO!
Post by nivek »
Sounds like tireshop is trying to dirtbag you into buying some old stock they may have laying around.
What I remind my tireguys of is that the 16 inch lowboy trailer tire tubes, radial or rag, work "just fine".
Lots more expense, but tube is heavyweight, very puncture resistant, and can take higher temps and will have the more break proof angled metal stems.
I'd rather buy good tubes now as compared to being up on the mountain cussing "cheap".
kL
'52 M-37 "Rusty Red" parted
Re: TUBES
HingsingM37 wrote:My local tire shop is telling me a 7:50 x 16 tube will work fine in place of the 9:00 x 16. True? :?
The best substitute if a 9.00X16 size isn't available is a 9.00X15 tube for a lowboy trailer tire. These will fit great & have the correct brass valve stem. They are available in radial type also if you are going with radial tires. Radial tubes & flaps are compatible with bias tires, bias tubes & flaps are NOT compatible with radial tires.
Thanks once again for your input gentlemen :)
powool
Post by powool »
http://www.innertubes.net/catalog/index ... 0fad1e0284
I've lost who said this:
"These tubes are made by International Tube and Tire (ITT) and have the same stem as the Non-Radial 9 x 16 tube VPW sells. They are 9/10/11 R15-16 Radial Truck Tubes, ITT Product Code 11430, with Stem TR75A, which is a Brass Stem, with a 90 degree bend that just comes to the inner edge of the Split Ring, or Combat Wheel ring, so it doesn't hang out where it can be damaged."
.Also, consider: 11.00R16 - Michelin tube 16P9 or 16P, with a 6M16 Michelin flap, valve stem on tube is # 1339 (metal)
I'm looking to buy from ITT tomorrow. I'll let you know how it goes...
Paul Anderson
powool
Post by powool »
I had no luck ordering from ITT - anyone have another online source for tubes and flaps?
Paul Anderson
Wallace Wade supplied mine:
http://www.wallacewade.com/
We buy from our local truck tire dealer, you can do the same & avoid shipping cost.
Re: TUBES
Was doing some cleaning in the parts container yesterday, found new 9.00X16 tubes & flaps for NDT's. If interested, give me a call or e-mail.
powool
Post by powool »
ITT seems not to be in business, or at least their web site is dead.
I wound up having a local tire guy out in the country get bias ply tubes - time was very short due to the police tagging my M37 for impound till I get it back on tires and re-tagged. Grrr... hate living in the city...
The same tire guy was not able to use the numbers I gave as Michelin part #'s. So I'd disregard those.
Paul Anderson
